×Hello,
i would like to ask, if it is possible to make a workflow condition so that an issue will not process to another status unless it will be linked with another issue of certain type. In other words, i would like to ask how to "force" user to link issue with another issue during a workflow.
Thank you for advices
You can use the JIRA Behaviours Plugin for this. Use this example for a detailed example for using a server-side script that validates the existance of an issue link.
