As an answer of mine explains, the "{{placeholder}}" inline monospace formatting is now deprecated:
It still is used but hasn't got the same rendering anymore. The border and background or the tag like appearance if you will is not any longer there.
However, I've been unable to locate a replacement. Surely one must exist?
{code}...or its myriad block counterparts are not a replacement.
Hello @Mr. Beedell, Roke Julian Lockhart (RJLB) ~ using the following in Text mode works for me:
{code:java}
yourtext{code}
HTH
I'm thankful for the response, but that's block formatting. I'm referring to inline formatting. If that's meaningless to you, I refer to w3schools.com/html/html_blocks.asp.
Help us plant more trees
