Search for the issues you want in it, then use "export to CSV" in the navigator options. Excel can read CSV files.
Open an existing filter from a dashboard or navigate to the search page. Select the projects and issues that you want to filter. In the top right you will see a drop down option for "Export". Click on that and select the export type. You can export in excel or as CSV in two ways;
Hope this helps.
using current fields no long available?
Thanks David - this is an excellent answer, when I am working with issues. But I want to download the data set associated with one of the standard Reports.
AFAIK unless I reproduce the fields that set up the Report, I can't actually export the report into CSV.
If CSV doesn't work for you, use the Better Excel Plugin to export search results to XLSX files.
Samples: http://www.midori-global.com/products/jira-better-excel-plugin/template-gallery
This is for a previous version of Jira I think - is there something more recent? None of the canned reports work for me - I just want a dumb sheet :((
I find jira to be very convoluted so no doubt the ask for a visual example was triggered by this frustration.
@Richard vw & @David Willox: Hey, y'all, just a heads up that we have community guidelines that require members to treat each other with respect — it's totally fine to ask for clarification of an answer, but antagonizing other members and name calling will not be tolerated. Thanks for your attention to this matter!
Hi team, if you are creating your report on confluence and only have export to word as an option, go to edit, here you will see the report as it's grey macro.
Click the grey macro box, and select view in Jira.
Here you can export on the top right to csv, xml, html, etc etc.
Hope this helps.
We need a visual step by step with pictures or a video. The words above are almost meaningless. The sentence ' using current fields (those visible in the filter display) which can be modified by clicking on "Columns" just underneath the export button and selecting the fields that you want to display for each item".... Is so cryptic it may as well be written in cuneiform . The word "Columns" is not present on the interface. The current fields refers to a space on the page somewhere, however the location of that space is dependant on prior knowledge that associates the title 'current fields' with that space. This is because the words 'current fields' does not appear anywhere in the interface.
Hi Richard,
Thank you for your condescending, ill observed and boneheaded response. Frankly I feel disinclined to help any further but an Atlassian community troll is such a rare and gloriously moronic thing I'll suit up and dive into this choking sea of moldy crap.
Assuming that you were able to decipher my crude and incoherent rock scratchings of the first sentence and made it as far as the search page you would see the following;
Then by clicking on "Export" you will see the elusive and definitely non-existent "Current fields" option.
Hope this helps!
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
