I need to generate a report which includes information about bug creation rate for a particular developer. Can I do this with Jira?
Hansi
Hey Hansi,
Firstly you need to create a filter based on the issue type bug and your developer as reporter:
issuetype = Bug AND reporter = "developer"
Then you can use the Recently Created Issues Report
I hope it helps you!
In my case, always bugs are raised after QA testing and hence, all bugs are raised by QAs. So always reporters of all bugs are QAs. So I think, I would not be able to use that filter :(
So why do you need the rate for a particular developer knowing that he does not create bugs?
