How to get IssueType in JavaScript ?
Mik
Hi Guys.
Maybee anyone know how to how to get IssueType in JavaScript ?
I am using JIRA 5.
My goal is modify Customfields depends on value in anoter one. I would like use onchange function for it, but my problem is I must call it only for one IssueType. ( I using this customfield for many IssueTypes).
Thanks a lot !
Regards
Mik
Renjith Pillai
August 14, 2012
AJS.$("#type-val").find('img').eq(0).attr("alt");
Mik
It's working! Thanks a lot !
Jobin Kuruvilla [Adaptavist]
August 14, 2012
Try AJS.$("#issuetype-field").val()
Mik
Hi Jobin
Thanks for quick answer. Unfortunately it say: Undefined
Regards
Mik
Basavaraj Nesargi February 9, 2017
var issuetype=AJS.$("#issue-create-issue-type").text();
Try the above script in latest JIRA version . (applicable on create issue JSP)
Register here ⬇️
