How to get IssueType using ProjectKey (JAVA API)?
Ramesh Lakshmanasamy August 1, 2018
I need to get Issue Type using Project Key in the way of JAVA API.
Ajay _view26_
Example for getting the IssueType
ComponentAccessor.getConstantsManager.getAllIssueTypeObjects
Alexey Matveev
August 1, 2018
If you want to get all issue types for a project, it will be like this
def projectKey = "you project key"
def project = ComponentAccessor.getProjectManager().getProjectByCurrentKey(projectKey)
ComponentAccessor.getIssueTypeSchemeManager().getIssueTypesForProject(project).each{
log.error(it.getName())
Sohail Anwar July 8, 2019
is this any api ?
Bastian Stehmann
Hi @Ramesh Lakshmanasamy,
I do not get what you try to do.
Do you want to get all issue types that are available in the project identfied by the project key?
Or do you mean the issue key and want to get the issue type of a specific issue?
