How to get Jira issue id from issue key
Sarangadhar.Sahani
Zephyr apis accept issueId. How to we programmatically get the corresponding issueId for an issueKey?
If we have to use combination of Jira and Zephyr apis, then how do we authenticate programmatically for Jira api calls like we do for Zephyr through JWT.
2 accepted
DPKJ
What platform are you on?
  1. Jira server
    • You can call <JIRA_BASE_URL>/rest/api/2/issue/{issueIdOrKey}
      • This api accept issue id or key as path parameter.
    • For authentication on server platform you have two options
      1. BasicAuth (base64 encoded username and password)
      2. oAuth
    • You can read more about it here https://docs.atlassian.com/software/jira/docs/api/REST/8.3.2/
  2. Jira Cloud
    • You can call <SITE_URL>/rest/api/3/issue/{idOrKey}
      • similar to server this api also accept issue id or key as path parameter
    • For authentication on cloud platform you have two options
      • BasicAuth with API Key (base64 encoded email and api key)
      • oAuth 2.0
    • You can read more about this here https://developer.atlassian.com/cloud/jira/platform/rest/v3/
Sarangadhar.Sahani
Thank you @DPKJ
DevajeetMicrosoft
August 15, 2022
I am getting 404 if I try GET/rest/api/2/issue/{issueIdOrKey} even though the issue exists for that key. Any help?
Antonio Gil Coto February 20, 2023
HI @DPKJ There is no issue.id for Jira Cloud as Smart Value
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
Although, following this doc https://confluence.atlassian.com/automation/find-the-smart-value-for-a-field-993924665.html, you can use the dot notation for whichever issue field ....
So now we can access Xray GraphQL API
https://xray.cloud.getxray.app/doc/graphql/addtestsetstotest.doc.html
Daniel Mende
April 26, 2023
@DevajeetMicrosofttry /rest/api/3/issue/{issueIdOrKey}
Ladislav Prchal
I retrieved some email like API 2 and 3 are being made obsolete... I wonder, is this still going to be functional? I would say it is different endpoint to Tempo, but I am not sure...
Sreenivasaraju P
August 18, 2019
Hi @Sarangadhar.Sahani ,
You can get it using REST API
https://community.atlassian.com/t5/Jira-questions/How-I-get-issue-id-of-particular-issue-in-Jira-Service-Desk/qaq-p/977378
If you want to get using JAVA API . You can user IssueMangaer class. From this you can get issue object using issuekey.
Sarangadhar.Sahani
Thank you @Sreenivasaraju P can you help me how the authentication work for calling  atlassian apis? Does it work through JWT like Zephyr?
