How to get List of Issue Object using ProjectKey?
Ramesh Lakshmanasamy June 16, 2018
I need to know list of Issues in a Single Project Using java API.
3 votes
Mark Markov
June 16, 2018
Hello @Ramesh Lakshmanasamy
Like this
def project = ComponentAccessor.getProjectManager().getProjectByCurrentKey("TEST")
def issueids = ComponentAccessor.getIssueManager().getIssueIdsForProject(project.id)
List<MutableIssue> issueList
issueids.each {it ->
issueList.add(ComponentAccessor.getIssueManager().getIssueObject(it))
Thanks @Mark Markov i tried above solution its working fine.
Mark Markov
June 18, 2018
You re welcome. If it helps you, please mark answer as accepted :)
Prakhar Srivastav {Appfire}
June 16, 2018
Hi @Ramesh Lakshmanasamy
I will suggest you to use below method. It will give you a list of all issue ids with which you can create issue Objects.
https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/issue/IssueManager.html#getIssueIdsForProject-java.lang.Long-
There is one direct method to get all issue objects , but that is being deprecated :
https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/issue/IssueManager.html#getProjectIssues-org.ofbiz.core.entity.GenericValue-
you can use jql via java api as well.
Regards
Prakhar
Register here ⬇️
