How to get Sprint Name using ScriptRunner Cloud Listener?
alexmears
Currently
Our Sprint names follow a YYMMDD convention.
Goal
We want to take the Sprint Name and populate a Date custom field in JIRA that we can then compare to Due Dates.
ScriptRunner Listener Script
// get custom fields
def customFields = get("/rest/api/2/field")
.asObject(List)
.body
.findAll { (it as Map).custom } as List<Map>
def inputid = customFields.find { it.name == 'Sprint' }?.id
def outputid = customFields.find { it.name == 'TESTING Expected Prod Deployment Date' }?.id
def projectKey = "OP"
if (issue == null || ((Map)issue.fields.project).key != projectKey) {
logger.info("Wrong Project \${issue.fields.project.key}")
return
def input = issue.fields[inputid].Get("name") as String
if (input == null) {
logger.info("Calculation using \${input1} and \${input2} was not possible")
return
def output = Date.parse("yyMMdd", input)
if (output == (issue.fields[inputid] as Date)) {
logger.info("already been updated")
return
put("/rest/api/2/issue/\${issue.key}")
.header("Content-Type", "application/json")
.body([
fields:[
(outputid): output
.asString()
Issue
The script fails at def input = issue.fields[inputid].Get("name") as String since .Get("name") is how I would imagine I would get the value from the Sprint, but it doesn't work that way.
I don't have much java expertise, so would appreciate any pointers anyone might have.
Kristian Walker (Adaptavist)
Hi Alex,
Thank you for your question.
I can confirm that to get the sprint value off an issue that you need to use the Jira Software API's rather than the standard get issue api as this just stores the sprint details as text.
I have created a sample script located here which you can run in the script Console in order to get the name of the sprint on a specified issue.
You will be able to use this sample script in order to modify your code to get the sprint value which you require.
If this response has answered your question can you please mark it as accepted so that other users can see it is correct when searching for similar answers.
Kristian
alexmears
Thank you for the response. The script returns the following error at line 21:
[Stack type checking] - No such property: name for class: java.lang.Object
alexmears
WOW, the error message in the script console is incorrect. This script works, which means my other scripts were working before but I wasn't running them due to the error message. 8hrs down the drain.
Thank you for your help.
Hi Alex,
Thankyou for confirming that your issue has been resolved.
I can confirm that Static Type Checking errors are just warnings where the compiler does not understand the code as described here and that scripts will still run with these type checking warnings.
Kristian
