How to get all Status in jira using java API?
Ramesh Lakshmanasamy June 29, 2018
I need to get all statuses using Java API.
Tansu Akdeniz
June 29, 2018 edited
Hi @Ramesh Lakshmanasamy,
You can use ConstantsManager.
import com.atlassian.jira.config.ConstantsManager;
import com.atlassian.jira.issue.status.Status;
ConstantsManager constantsManager = ComponentAccessor.getConstantsManager();
Collection<Status> statuses = constantsManager.getStatuses();
Tansu
I need to get StatusID and StatusName @Tansu Akdeniz.When i loop using collection object i cant get status name and Id.
Tansu Akdeniz
You can take id, name etc values inside the loop.
for(status in statuses){
    println "Status Name: " +status.getName();
    println "Status Id: " +status.getId();
Ramesh Lakshmanasamy July 6, 2018
Thanks @Tansu Akdeniz
Tansu Akdeniz
You are welcome @Ramesh LakshmanasamyIf my answer helped to solve your question, would you please accept it. So that, other people will be able to find this answer easily for similar questions.
Ramesh Lakshmanasamy July 8, 2018
sure
