How to get all filter in jira server?
Dang Thi Thuy Tien
January 22, 2019
I want to get all filter, something like this table.
How can I do that?
Thank you,
2 accepted
Alexey Matveev
January 22, 2019
If you want to get all filters (even filters, which are not shared with you and private filters), you need to execute sql to your database:
SELECT s.filtername, s.authorname, s.DESCRIPTION FROM searchrequest s
Dang Thi Thuy Tien
January 22, 2019
Thank you @Alexey Matveev. In the table searchrequest i can find all information I want.
But I wonder, do we have any other way to get that information via java class?
Alexey Matveev
January 22, 2019
I think it is possible though I do not have a script.
Dang Thi Thuy Tien
January 22, 2019
I found the solution for this question is:
private final SearchRequestService searchRequestService;
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
searchRequestList = new ArrayList<>(searchRequestService.getOwnedFilters(user));
https://community.developer.atlassian.com/t/how-to-get-all-filter/26526/5
Yassin
Try out the free App "My Filter Manager for Jira" this can be used by admins to check the usage of certain fields in filters or filters owned by inactive users.
https://marketplace.atlassian.com/apps/1224201/my-filter-manager-for-jira?hosting=server&tab=overview
Yogesh Mude
January 22, 2019
HI @Dang Thi Thuy Tien\
You can use the JQL to get all the filters.
like filter in (....)
Dang Thi Thuy Tien
January 22, 2019
I want to get all filter scheme ;)
Thank you
Like samia likes this
Charly [DEISER]
January 22, 2019
Hi @Dang Thi Thuy Tien
If you are a Jira administrator you can see all filters here: <your jira base url>/secure/admin/filters/ViewSharedFilters.jspa
Hope this helps!
Alexey Matveev
January 22, 2019
Private filters will not be in the list.
Like # people like this
Anthony Frank
April 28, 2022
I am an admin at my company and it I can view Private filters using the above link.
