How to get all statuses for one project type with SQL?
Dmitrii November 11, 2020 edited
I know that there is a REST endpoint /rest/api/2/project/{prject_key}/statuses which will return statuses for a project, in objects for a particular type. Knowing the project id and issue type id, need to get a list of statuses related to the issue type with SQL.
How to do it?
Nic Brough -Adaptavist-
November 11, 2020
SQL is a last restort, the worst possible way to get information out of a Jira database.  You really should avoid doing it this way.
However, if you insist, you'll need to
  • Read Project to find the project ID
  • Read nodeassociation to get the workflow scheme for the project
  • Read workflowscheme to get the workflows associated with the project
  • Read each workflow out of jiraworkflows
    • Parse the xml you get for the step to status mappings
      • Read issuestatus to get the status name
Learn more
