How to get checkbox value with scriptrunner in post-function?
ANN LEE May 12, 2016
I need to use scriptrunner to create number of sub-task based on checkbox value. According to an example in Atlassian Answers, I copied following code in my script with some of my modification:
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
// get checkboxes fields value
def subComponentFld = getFieldByName("Additional Access")
customField = customFieldManager.getCustomFieldObject(subComponentFld.getFieldId())
config = customField.getRelevantConfig(getIssueContext())
options = optionsManager.getOptions(config)
def optionsToSelect = options.findAll { it.value in ["Email Required", "Network Login Required", "SAP Access Required"] }
if (optionsToSelect ???  ) { }
Problem encountered:
1) scriptrunner cannot find matching method for "getFieldByName". Which extra library need to be imported?
2) I guess the value has been read into optionsToSelect , but how to check?
I am very new to JIRA script. Please help!
Thanks lots!!!!!!!!!!!
adammarkham
May 17, 2016
You can get what checkboxes have been selected by using:
def issue = ComponentAccessor.getIssueManager().getIssueObject("ISSUE-1")
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Additional Access");
def selectedValues = customField.getValue(issue)*.value
if ("Email Required" in selectedValues) {
	// Do something
ANN LEE May 19, 2016
Thanks lot!!!!!!!!!!!
Ashraful Hasan [Adaptavist]
Hi - The following example is a post function script which reads custom field [in this case checkbox] values and create subtasks based on selected values. The script contains important inline comments which explain code lines or functions:
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.project.Project
import groovy.transform.Field
import com.atlassian.jira.config.SubTaskManager
@Field
SubTaskManager subTaskManager = ComponentAccessor.getSubTaskManager()
@Field
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
//name of the custom field
def customFieldName = 'Checkboxes'
//get the custom field object
def customFieldObject = customFieldManager.getCustomFieldObjectByName(customFieldName)
Issue issue = issue
//get all the values of the custom field
def customFieldValues = customFieldObject.getValue(issue)
//loop through the values and create sub tasks
//change the case value as per requirements such as "Email Required" or "SAP Access Required"
customFieldValues.each { LazyLoadedOption it ->
    def optionValue = it.getValue()
    switch (optionValue){
        case "Yes":
            def newIssue = createIssue(issue, optionValue)
            createSubTask(issue, newIssue)
            break
        case "No":
            break
        case "Maybe":
            break
 * Create a new sub task
 * @param issue
 * @param newIssue
 * @return
private createSubTask(Issue issue, Issue newIssue){
    if(newIssue) {
        subTaskManager.createSubTaskIssueLink(issue, newIssue, user)
 * This function creates a new issue. issueInputParameter should be set according to
 * the requirement
 * @param issue
 * @param optionValue
 * @return
private Issue createIssue(Issue issue, String optionValue) {
    Project project = issue.getProjectObject()
    IssueService issueService = ComponentAccessor.issueService
    IssueInputParameters issueInputParameters = issueService.newIssueInputParameters()
    def constantsManager = ComponentAccessor.getConstantsManager()
    //get issue type such as 'Bug'
    def bugIssueType =  constantsManager.getAllIssueTypeObjects().findByName("Bug")
    issueInputParameters.setProjectId(project.id)
        .setIssueTypeId(bugIssueType.id)
        .setReporterId(user.name)
        .setSummary("Test issue _" + optionValue)
    IssueService.CreateValidationResult createValidationResult = issueService.validateCreate(user, issueInputParameters);
    Issue newIssue
    if (createValidationResult.isValid()) {
        IssueService.IssueResult createResult = issueService.create(user, createValidationResult);
        if (createResult.isValid()) {
            newIssue = createResult.issue
    return newIssue
Thank you so much for your help! It works for me now!
ANN LEE May 16, 2016
I need to send the sub-ticket according to 3 check-box value. But I tried many times still get customField null. Please let me know if following code is all right? Is there any easy way to get value from the checkbox?
Thanks ahead!
def fieldid = new String[3]
fieldid[0] = "Email Required"
fieldid[1] = "Network Login Required"
fieldid[2] = "SAP Access Required"
List optionsList = (List)issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Additional Access"));
if(optionsList != null) {
def i
for (i = 0; i <3; i++) {
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(fieldid[i]);
if (customField != null && i == 0) {
assigneeIdList.add("sduffy")
summariesList.add("Email Required for New Hired")
if (customField != null && i == 1) {
assigneeIdList.add("drobinson")
summariesList.add("Network Login Required for New Hired")
if (customField != null && i == 2) {
assigneeIdList.add("coschbach")
summariesList.add("SAP Access Required for New Hired")
Help us plant more trees
