How to get current issue object in Behaviour ?
Paridhi Agarwal March 7, 2018
I am using JIRA version 7.2.9 and Script Runner version 5.0.4.
I want to set the Security Level for the current issue object in Behaviour. But I am not able to get the current issue object.
Can someone please help ?
8 votes
Alexey Matveev
March 8, 2018
In behaviours you can either use the underlyingIssue variable or getIssueContext()
Slava Gefen
This helped, thanks @Alexey Matveev
Larry Matter May 15, 2020
As @Kabelo Mokgoro  suggests, underlyingIssue is correct for a Behavior server-side script.
issueContext is not of type issue.
For example:
def wf = workflowManager.getWorkflow(underlyingIssue)
ragif.ahmadov
May 21, 2020
i have same problem
my code is
import com.atlassian.jira.issue.MutableIssue;
def textCf = customFieldManager.getCustomFieldObjectByName("Client")
String clientName = underlyingIssue .getCustomFieldValue(textCf)
but i get error "the variable underlyingIssue is undeclared."
i have tried with issue. and then get error "the variable issueis undeclared."
so can you help me pls.
Vedant Kulkarni
@ragif.ahmadov  to get the field value you can directly use like this -
String clientName = getFieldByName("Client").getValue()
no need for IssueContext. Just make sure the field should be present on the form/pop-screen
Suhas P
March 8, 2018
In actual script you can use 'issue' for current issue object.
For testing in script console you can use following,
def issueManager = ComponentAccessor.getIssueManager()
def issue = issueManager.getIssueObject("ABC-123")
Paridhi Agarwal March 8, 2018
I have already tried using "issue" object, but it is giving me the error 'the variable [issue] is undeclared'.
Please refer the logs attached.
Nic Brough -Adaptavist-
March 8, 2018
That suggests that you have not used the last line of Suhas's code to get the issue.
I wan't to get current issue in Behaviour, in this case I will directly use 'issue' for current issue object (as depicted in screenshot below). Am I right ?capture2.png
Suhas P
March 9, 2018
You should use 'issueContext' instead of 'issue'.
Vineela Durbha
@Suhas P
Have you tried to use issue context and got the results?
Kabelo Mokgoro October 31, 2019
@Paridhi Agarwal Have you tried using the "underlyingIssue" variable instead?
Like • Jordan likes this
