Currently, to get a custom field object or value, I use such approach:
MutableIssue issue = issue
Long someCustomFieldId = 10206L
def object(Long customFieldId) {
ComponentAccessor.customFieldManager.getCustomFieldObject(customFieldId)
def value(Long customFieldId) {
issue.getCustomFieldValue(object(customFieldId))
return "Field object: ${object(someCustomFieldId)}, field value: ${value(someCustomFieldId)}"
But instead of calling object(someCustomFieldId) and value(someCustomFieldId), I want to use someCustomFieldId.object and someCustomFieldId.value
For implementing, I have created a class
class Field {
Long customFieldId
final object
final value
Field(customFieldId) {
this.customFieldId = customFieldId
def getObject() {
ComponentAccessor.getCustomFieldManager().getCustomFieldObject(customFieldId)
def getValue() {
issue.getCustomFieldValue(getObject())
def someCustomField = new Field(11002L)
Calling someCustomField.object returns a custom field object, but calling someCustomField.value does not return any value.
An error occurred:
groovy.lang.MissingPropertyException: No such property: issue for class: Field Possible solutions: value
How to get current issue object in a custom class?
This usually depends on where you are trying to get a handle on the issue. What is the context for the code you are running?
I need to operate with an issue fields values and/or objects.
Previously I defined all necessary custom field ID in Long format and used something like this:
def customFieldManager = ComponentAccessor.customFieldManager
Long businessEmail = 12345L
def businessEmailObject = customFieldManager.getCustomFieldObject(businessEmail)
def businessEmailValue = issue.getCustomFieldValue(businessEmailObject)
if (businessEmailValue) {
else {
issue.setCustomFieldValue(businessEmailObject, someValue)
It is ok, if I use 2-3 issue fields in my code. But in case of 10-20 fields it is not ok.
Therefore I want to use some simple and short approach for custom fields objects and values operations.
I am sorry, I was not clear. What is the context the code will run in? What does a user do that makes it run?
Ok, then
cf = customFieldManager.getCustomFieldBy<something-type>(<something-name>)
issue.getCustomFieldValue ( cf )
is the right approach. You'll get an object back which is of the type of the stored data (string, option, date/time, number etc). The <something-type> would be "by name" or "by ID", and you need to feed it the name or id of the field you want to get.
Register today
