How to get fields from different subtasks on eazyBI report
Xavi fernandez February 10, 2017
The idea is:   get fields from Task, and also fields from subtask of type "A" and "B" on the same row.
How can I do it?
Example
       Key Task | due date Task| status subtask type A | status subtask type B
Thanks.
eazyBI Support
February 28, 2017
Hi Xavi,
Here is an example how to retrieve a string value, in this case, Sub-task status, from the first sub-task with issue type 'Sub-task A'.
Generate(
  Filter(
    [Issue].[Issue].GetmembersByKeys(
      [Issue].CurrentHierarchyMember.get('Sub-task keys')
     [Measures].[Issue type] = 'Sub-task A')
  .Item(0),
  Cast( [Measures].[Issue status] as String), ",")
The GetmembersByKeys function gets a set of all subtasks of an issue, a Filter filters out the ones with type 'Sub-task A'. Generate function creates a string from this Sub-task status.
Deleted user June 13, 2022
can you show how it should look like on eazybi ?
Oskars Laganovskis
June 20, 2022
Hello Marcelo,
You were looking for a measure that checks if a parent issue is resolved within the current time period - how many of its sub-tasks of a specific type - "Block" are in a specific resolution - "Done".
You needed to keep the default hierarchy in the Issue dimension since you wanted to filter issues by parent task resolution date.
​Since the sub-tasks are built within the sub-task hierarchy and their issue keys are not available as a property of the parent task - the expression needs to switch between hierarchies during the calculation.
​The MDX expression for the calculated measure was as follows.
CASE WHEN
[Measures].[Issues resolved]>0
THEN
NonZero(
 Count(
  Filter(
   DescendantsSet([Issue.Sub-task].[Parent].GetMemberByKey([Issue].CurrentHierarchyMember.Key),
                  [Issue.Sub-task].[Sub-task]),
   [Issue Type].[Issue Type].GetMemberNameByKey([Issue].CurrentHierarchyMember.Get('Issue type ID'))="Block"
   AND
   [Resolution].[Resolution].GetMemberNameByKey([Issue].CurrentHierarchyMember.get('Resolution ID')) = "Done")
END
​Regards,
​Oskars / support@eazyBI.com
Deleted user June 28, 2022
Hi @Oskars Laganovskis
I try to visualize it this way but it is not possible
Oskars Laganovskis
July 12, 2022
Hi @[deleted] ,
Please select the Issue level on the default hierarchy.
Alternatively, you might sum the values for all issues within the project by creating the following construction.
Sum(
Descendants([Issue].CurrentMember, [Issue].[Issue]),
--the actual calculation for each issue
<the previously provided code>)
 That would return values on the project level.
Read the story
