How to get groups, which are assigned to a specific role in a project?
Finn Bökenkamp
January 22, 2018
I want to get the names of groups, which are assigned to a role in a project, but only found a way to get all usernames that are assigned to a role, with the following:
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.project.Project;
import com.atlassian.jira.security.PermissionManager;
import com.atlassian.jira.security.roles.ProjectRole;
import com.atlassian.jira.security.roles.ProjectRoleActors;
import com.atlassian.jira.security.roles.ProjectRoleManager;
import com.atlassian.jira.user.ApplicationUser;
Collection<Project> projects = permissionManager.getProjects(new ProjectPermissionKey("BROWSE_PROJECTS"), appUser);
ProjectRoleManager projectRoleManager = ComponentAccessor.getComponentOfType(ProjectRoleManager.class);
ProjectRole projectRole = projectRoleManager.getProjectRole("Role Name");
for(Project project : projects){
ProjectRoleActors projectRoleActors = projectRoleManager.getProjectRoleActors(projectRole, project);
System.out.println(projectRoleActors.getUsers().toString());
 Is there any way to get the groupnames instead of all usernames?
miikhy
January 22, 2018
You might want to use the ProjectRoleManager.getProjectIdsContainingRoleActorByNameAndType() method, you can define which type of actor you want to get, in your case it would be ProjectRoleActor.GROUP_ROLE_ACTOR_TYPE.
More details here: https://docs.atlassian.com/software/jira/docs/api/7.0.2/com/atlassian/jira/security/roles/ProjectRoleManager.html#getProjectIdsContainingRoleActorByNameAndType-java.lang.String-java.lang.String-
Hope this helps!
Cheers
miikhy
January 22, 2018
This is based on knowing the group name. If you don't want to check all groups individually, you might want to search for an alternative solution. Will keep you posted if I can find one!
Cheers
Finn Bökenkamp
January 22, 2018
thanks for this, but you already say it. It would be more comfortable if I get the groupnames directly by the project, instead of run through all groupnames individually and compare each projectId with the result list of the function.
Would be great if there is any solution! Otherwise I go on with this one...
miikhy
January 23, 2018
Sure! Please keep us posted if you find any better solution, very interesting question :)
Santwana Sarangi {Appfire}
August 28, 2019
Hi @Finn Bökenkamp ,
Here is the working solution to get the groups assigned to a particular project role in a project.
        Set<String> projGroupNames =new HashSet<String>();
        ProjectRole projectRole = projectRoleManager.getProjectRole("Administrators");
        for(RoleActor actor : projectRoleActors.getRoleActorsByType(ProjectRoleActor.GROUP_ROLE_ACTOR_TYPE)) {
            projGroupNames.add(actor.getParameter());
Hope this helps.
Santwana
Like • Rolf Lader likes this
Ankush Kumar February 22, 2022
Hi @Santwana Sarangi {Appfire}
you have working script, I am trying to fetch group based on role.
February 22, 2022
Hi @Ankush Kumar ~ I have already provided the above. Hope that helps.
Ankush Kumar February 22, 2022 edited
@Santwana Sarangi {Appfire} getting error "unable to resolve class RoleActor"
Read the story
