Sign up Log in
How to get inactive users of JIRA with jelly or groovy script?
Rumceisz
Hi All,
is it possible to get the list of inactive users of JIRA by jelly or groovy?
Note, I do not have access to DB so SQL is not possible.
Thanks in advance,
Rumi
4 votes
Henning Tietgens
February 11, 2014
Yes.
import com.atlassian.jira.user.util.UserManager
UserManager userManager = ComponentAccessor.getUserManager()
userManager.getUsers().findAll{user -> !user.isActive()}.each { user ->
Tushar Kamble November 15, 2016
Hello Henning,
Can we get list of inactive users for specific time, like I need list of users who are inactive from last 30 days?
Henning Tietgens
November 15, 2016
if you define inactive as "not logged in" you can use something like this.
def crowdService = ComponentAccessor.crowdService
def ofBizUserDao = ComponentAccessor.getComponent(OfBizUserDao)
def userUtil = ComponentAccessor.userUtil
def dateLimit = (new Date()) - 30
userUtil.getUsers().findAll { it.isActive() }.each {
	def user = crowdService.getUserWithAttributes(it.getName())
	def lastLoginMillis = user.getValue('login.lastLoginMillis')
	if (!lastLoginMillis?.isNumber()) {
		def tu = ofBizUserDao.findByName(user.directoryId, user.name)
		lastLoginMillis = tu.getCreatedDate()?.time
	if (lastLoginMillis) {
		def d = new Date(Long.parseLong(lastLoginMillis))
		if (d.before(dateLimit)) {
			// not logged in for 30 days...
If the user never was logged in, this uses the created date for calculating the time of "inactivity".
Henning
Like Pantham Akhil likes this
Tushar Kamble November 16, 2016
Henning Tietgens
November 16, 2016
Ah, I missed an import while copying..
import com.atlassian.jira.crowd.embedded.ofbiz.OfBizUserDao
Henning Tietgens
November 16, 2016
And you have to do something at the position of the comment (// blue), like
def result = ""
    String lastLoginMillis = user.getValue('login.lastLoginMillis')
			result += "${user.displayName} (${user.name})<br>"
result
to print a list of "inactive" users.
Please note the change to String lastLoginMillis, otherwise you'll get a runtime error.
Henning
Like Tushar.Kamble likes this
Thanks, it works perfectly well..
Tushar
Stephen Hayden August 9, 2017
I can't seem to comment on this, it says I'm a spammer :(
There it goes, now for my actual comment:
Does this need to be revised?  I'm getting
Cannot invoke method findByName() on null object.
Like Josh Simnitt likes this
Henning Tietgens
August 9, 2017
There were some changes in JIRA 7. Here's my current script to deactivate inactive users:
import com.atlassian.crowd.embedded.api.UserWithAttributes
import com.atlassian.crowd.embedded.spi.UserDao
import com.atlassian.jira.application.ApplicationAuthorizationService
import com.atlassian.jira.application.ApplicationKeys
import com.atlassian.jira.bc.user.ApplicationUserBuilderImpl
import com.atlassian.jira.bc.user.UserService
import com.atlassian.jira.bc.user.search.UserSearchParams
import com.atlassian.jira.bc.user.search.UserSearchService
def test = true // to really deactivate users, change to false
int numOfDays = 182 // Number of days the user was not logged in
def blockedUsers = // User who should not be deactivated
'administrator'
def maximumNumberOfUsers = 10000 // search is restricted to find at max this number of users
def userSearchService = ComponentAccessor.getComponent(UserSearchService)
def userService = ComponentAccessor.getComponent(UserService.class)
def userDao = ComponentAccessor.getComponent(UserDao)
def applicationAuthorizationService = ComponentAccessor.getComponent(ApplicationAuthorizationService)
def updateUser
def updateUserValidationResult
Date dateLimit = (new Date()) - numOfDays
String result = ""
def userSearchParamsBuilder = new UserSearchParams.Builder()
.allowEmptyQuery(true)
.ignorePermissionCheck(true)
.maxResults(maximumNumberOfUsers)
def allActiveUsers = userSearchService.findUsers("", userSearchParamsBuilder.build())
result += "All active Users: ${allActiveUsers.size()}<br>"
allActiveUsers.findAll {
!blockedUsers.contains(it.name) &&
applicationAuthorizationService.canUseApplication(it, ApplicationKeys.SOFTWARE) ||
applicationAuthorizationService.canUseApplication(it, ApplicationKeys.SERVICE_DESK)
}.each { appUser ->
UserWithAttributes user = crowdService.getUserWithAttributes(appUser.getName())
def start_text = "Last Login was"
if (user.directoryId && user.name) {
def tu = userDao.findByName(user.directoryId, user.name)
lastLoginMillis = tu?.getCreatedDate()?.time
start_text = "Not logged in, created on"
} else {
start_text = "SOMETHING WRONG: $user.directoryId && $user.name"
Date d = new Date(Long.parseLong(lastLoginMillis))
updateUser = (new ApplicationUserBuilderImpl(appUser)).active(false).build()
updateUserValidationResult = userService.validateUpdateUser(updateUser)
if (updateUserValidationResult.isValid()) {
if (!test) {
userService.updateUser(updateUserValidationResult)
result += "Deactivated ${updateUser.name} - $start_text ${d.format("dd.MM.yyyy hh:mm")}"
} else {
result += "Update of ${updateUser.displayName} (${updateUser.name}) failed: ${updateUserValidationResult.getErrorCollection().getErrors().entrySet().join(',')}"
result
Henning
Like # people like this
Mike
December 4, 2017
Hi Henning
Regarding your script for JIRA 7. What would be the script if I nly need to display user who did not login in the last 60 days without deactivationg them.
Thanks for your help,
Elvir
Henning Tietgens
December 4, 2017
Hi Elvir,
just exchange the inner part of if (d.before(dateLimit)):
result += "Inactive user: ${appUser.name} - $start_text ${d.format("dd.MM.yyyy hh:mm")}<br>"
Henning
Tushar.Kamble
@Henning Tietgens ,
Can we use this groovy script with cloud script runner to get the inactive users and projects?
Asif Chowdhury
Hi Henning, is it possible to deactivated user by using name for any position like team lead, administrator. Thanks for your time.
Henning Tietgens
December 15, 2019
Hi Asif, I don't understand your question. What do you mean with "position"? The script could deactivate every user, as long as this user is not component or project lead in any project.
Asif Chowdhury
Hi Henning,
I have written a groovy script to deactivate users. The issue I am running into is that the script will fail if the user is a component lead or project lead.  What I want to do is check if the user is a component lead and remove them if they are. So far I have been struggling to do so. (My current version of Jira 8.1.1)
Any help would be much appreciated.
Henning Tietgens
December 17, 2019
Ah, ok, understand. Try to integrate this into your script:
import com.atlassian.jira.bc.project.component.MutableProjectComponent
import com.atlassian.jira.project.UpdateProjectParameters
def projectManager = ComponentAccessor.projectManager
def projectComponentManager = ComponentAccessor.projectComponentManager
ApplicationUser user // the user who should be deactivated
ApplicationUser replacementUser // the user who should be used as project/component lead instead
// Check if user is component lead
def components = userUtil.getComponentsUserLeads(user)
components?.each{ component ->
def mutProjComp = MutableProjectComponent.copy(component)
mutProjComp.setLead(replacementUser?.name)
projectComponentManager.update(mutProjComp)
// Check if user is project lead
def projects = userUtil.getProjectsLeadBy(user)
projects?.each{project ->
def updateProjectParameters = UpdateProjectParameters.forProject(project.id).leadUserKey(replacementUser?.key)
projectManager.updateProject(updateProjectParameters)
Asif Chowdhury
Hi Henning
Thanks for your prompt response. I tried to integrate your code in my script but still its not working. Could you please give me the full script.
Thanks in advance.
Henning Tietgens
December 20, 2019
Hi Asif,
I would suggest you post your script and the error you get and I will help you to get it going.
Best, Henning
Asif Chowdhury
Hi Henning,
I would like to do remove/deactivate Project Lead, Component Lead from the project who aren't available in project and replace them automatically with current Project Lead, Component Lead. (Jira v8.1.1)
I will be grateful for any help you can provide.
Henning Tietgens
January 15, 2020
Hi Asif,
how do you define "aren't available in project" and "current Project Lead, Component Lead"?
Best,
Henning
Asif Chowdhury
Hi Henning,
Actually what I want to do is check if the user is a component lead/ project lead and who isn't anymore in project/company remove them automatically and replace another project lead/ component lead in this place.  Any help would be much appreciated.PL.jpg
Henning Tietgens
January 16, 2020
Hi Asif,
mmh, ok, so that's the same as in December. You should combine the scripts from comments from Aug 09, 2017 and Dec 17, 2019 • edited. If you get an error after doing this, you can post your combined script here and I'll take a look what's wrong.
Best,
Henning
Asif Chowdhury
Hi Henning,
I'm trying to combine with this script but it shows error. Could you please tell what can I do.
Thanks a lot for your help
import com.atlassian.crowd.embedded.impl.ImmutableUser
import com.atlassian.jira.user.DelegatingApplicationUser
def userName = "..."
def User
if (!componentsLeadedBy && !projectLeadedBy)
log.info "userName doesn't lead any component or project"
else {
//remove userName from project lead roles
if (projectLeadedBy.size() > 0)
for (project in projectLeadedBy) {
projectManager.updateProject(project, project.name, project.description, "", project.url, project.assigneeType);
//remove userName from component lead roles
if (componentsLeadedBy.size() > 0)
for (component in componentsLeadedBy) {
MutableProjectComponent newComponent = MutableProjectComponent.copy(component)
newComponent.setLead("")
projectComponentManager.update(newComponent)
def listUsers = userManager.getUsers().findAll{user -> user.name.equals(userName)}
if (listUsers.size() > 0)
return "User userName does not exist"
ImmutableUser.Builder builder = ImmutableUser.newUser(listUsers[0]);
builder.active(false);
def updatedUser = new DelegatingApplicationUser(applicationUser.key, builder.toUser())
UserService.UpdateUserValidationResult updateUserValidationResult =
userService.validateUpdateUser(updatedUser)
return "User ${applicationUser.name} deactivated";
} else {
return updateUserValidationResult.getErrorCollection()
Henning Tietgens
January 16, 2020
Hi Asif,
you have to get a user first before you try to determine if the user is a component lead etc. This part is missing before the first use auf "user".
Ashok V Jose
June 11, 2020
Hi @Henning Tietgens
I was also looking for a solution to check the inactive users
I am able to connect to Jira from a Groovy script, I am successful at connecting and sending jql statements, however I dont have the below classes, are the below free classes and can be downloaded from somewhere if free  or do they need licenses ?
Henning Tietgens
June 12, 2020
The classes are supplied by Jira itself. You need to run the script from the Script Console provided by Script Runner.
Ashok V Jose
June 15, 2020
Hi Henning,
But I am running from a remote box. So, I thought I can have a a jar file in the classpath ?  I dont have the Jira script console in this box.
Henning Tietgens
June 15, 2020
The script console can be opened from within Jira. You don't need direct access to the server. Try /plugins/servlet/scriptrunner/admin/console on your Jira web address.
Murthy Dusanapudi June 10, 2021
Hi @Henning Tietgens can you please me with the script for getting the list of users in jira  Name, Email Address, and active and in active users list and created , last updated date in a single script? is that possible to get all these details in a single script? please help me in this thank you in advance
Henning Tietgens
June 11, 2021
Hi Murty,
try this
def userManager = ComponentAccessor.userManager
result = "Name\tEmail\tActive\tCreated\tUpdated\n"
userManager.getAllUsers().each { u ->
def uo = userDao.findByName(u.directoryId, u.name)
def created = uo?.getCreatedDate()
def updated = uo?.getUpdatedDate()
result += "${u.displayName}\t${u.emailAddress}\t${u.active}\t$created\t$updated\n"
"<xmp>$result</xmp>"
Murthy Dusanapudi June 14, 2021
Tnq @Henning Tietgens  sorry for that i need this information in confluence actually...how can i get that information in confluence??
hi @Henning Tietgens can you please help me with the script for getting the list of users in Confluence., Name, Email Address, and active and in active users list and created , last updated date in a single script? is that possible to get all these details in a single script? please help me in this thank you in advance
Henning Tietgens
June 15, 2021
Hi Murthy,
try this.
import com.atlassian.crowd.embedded.api.ApplicationFactory
import com.atlassian.crowd.manager.application.ApplicationService
import com.atlassian.crowd.model.user.TimestampedUser
import com.atlassian.sal.api.component.ComponentLocator
import com.atlassian.user.UserManager
def userManager = ComponentLocator.getComponent(UserManager)
def applicationService = ComponentLocator.getComponent(ApplicationService)
def applicationFactory = ComponentLocator.getComponent(ApplicationFactory)
def application = applicationFactory.getApplication()
def result = "Name\tEmail\tActive\tCreated\tUpdated\n"
def created
def updated
userManager.getUsers().each { u ->
def modelUser = applicationService.findUserByName(application, u.name)
if (modelUser instanceof TimestampedUser) {
def timestampedUser = modelUser as TimestampedUser
created = timestampedUser.getCreatedDate()
updated = timestampedUser.getUpdatedDate()
} else {
created = null
updated = null
result += "${modelUser.displayName}\t${modelUser.emailAddress}\t${modelUser.isActive()}\t$created\t$updated\n"
Murthy Dusanapudi June 16, 2021
Hi @Henning Tietgens  tnq but it is not working for me and i have a script in Jira which gives all the details in a table
import com.atlassian.jira.security.login.LoginManager
import java.text.SimpleDateFormat;
import java.util.Date;
import com.atlassian.jira.user.util.UserUtil
UserUtil userUtil = ComponentAccessor.getUserUtil()
def loginManager = ComponentAccessor.getComponentOfType(LoginManager.class)
def users=ComponentAccessor.getUserUtil().getUsers()
StringBuilder builder=new StringBuilder()
builder.append("<table border = 1><tr><td><b>User Name</b></td><td><b>Full Name</b></td><td><b>eMail Address</b></td><td><b>Last Login</b></td><td><b>Status</b></td><td><b>Group</b></td></tr>")
users.each{
Long lastLoginTime = loginManager.getLoginInfo(it.username).getLastLoginTime()
String activeStatus=it.active
if(activeStatus=="false")
builder.append("<tr><td>"+it.username+"</td><td>"+it.displayName+"</td><td>"+it.emailAddress+"</td><td>Inactive User</td><td>"+it.active+"</td></tr>")
else if(lastLoginTime==null)
builder.append("<tr><td>"+it.username+"</td><td>"+it.displayName+"</td><td>"+it.emailAddress+"</td><td>Logon not found</td><td>"+it.active+"</td></tr>")
else if(userUtil.getGroupsForUser(it.getName()).size() == 0)
builder.append("<tr><td>"+it.username+"</td><td>"+it.displayName+"</td><td>"+it.emailAddress+"</td><td>No Group added</td><td>"+it.active+"</td></tr>")
else{
Date date=new Date(lastLoginTime);
SimpleDateFormat df2 = new SimpleDateFormat("dd/MM/yy hh:mm");
String dateText = df2.format(date);
builder.append("<tr><td>"+it.username+"</td><td>"+it.displayName+"</td><td>"+it.emailAddress+"</td><td>"+dateText+"</td><td>"+it.active+"</td></tr>")
builder.append("</table>")
return builder
can you please do change to work for confluence...i am trying a lot to change but unable to do so can you please do that for ...Thanks in advance
Henning Tietgens
June 16, 2021
Hi @Murthy Dusanapudi, did you run my last script in the script console of Confluence (you need Script Runner for Confluence)? If yes, what error did you get?
Like Murthy Dusanapudi likes this
Hi @Henning Tietgens i am getting those details with ur script and but they want it in a table if possible can you please do that for me ...Tnq
Henning Tietgens
June 16, 2021
Hi @Murthy Dusanapudi , you should learn/understand what you are doing... Scripting could be dangerous and simply copying scripts from web sites could lead to unwanted effects..
Nevertheless, here the script with html output and last login
import com.atlassian.confluence.security.login.LoginManager
import groovy.xml.MarkupBuilder
def loginManager = ComponentLocator.getComponent(LoginManager)
def df = new SimpleDateFormat("dd/MM/yy hh:mm")
def created
def updated
def lastLogin
def writer = new StringWriter()
def builder = new MarkupBuilder(writer)
builder.html() {
table(border: 1) {
tr {
td {b"User Name"}
td {b"Full Name"}
td {b"eMail Address"}
td {b"Status"}
td {b"Created"}
td {b"Updated"}
td {b"Last login"}
userManager.getUsers().each{u ->
def lastSuccessfulLoginDate = loginManager.getLoginInfo(u.name).lastSuccessfulLoginDate
if (lastSuccessfulLoginDate) {
lastLogin = df.format(lastSuccessfulLoginDate)
} else {
lastLogin = "not logged in"
created = df.format(timestampedUser.getCreatedDate())
updated = df.format(timestampedUser.getUpdatedDate())
} else {
created = "unknown"
updated = "unknown"
tr {
td modelUser.name
td modelUser.displayName
td modelUser.emailAddress
td modelUser.isActive()?"Active":"Inactive"
td created
td updated
td lastLogin
return writer.toString()
Hi @Henning Tietgens Thank you soo much it is working... and i am new to scripting now learning....and i don't have any knowledge in coding that's why i am searching here on web....will try to learn ...Thank you soo much
Murthy Dusanapudi June 27, 2021
Hi @Henning Tietgens can i send this table data as an email attachment to my manager using script? can you please help me in this ...Thanks in advance
Pantham Akhil
Hi @Henning Tietgens seen that you helped a lot of ppl in scripting ..i am new to script and unable solve one thang can u plz help me...
" we have 7 users in Jira-admins group so we don't want add any add any other user to that group, if any user accidentally added to that group then an email has to be sent to me or my team mate" ... can you please me to write a script for this please ..
def groupManager = ComponentAccessor.getGroupManager()
String groupName = "jira-administrators"
groupManager.getUsersInGroup(groupName)
using this script i am getting the list of users in admin group ..can you please help me in this. tnq
Tom Keidar
Here is a Jira cloud addon developed by my company that allows you to search, filter and bulk delete users:
https://marketplace.atlassian.com/apps/1221764/user-management-by-toros
In addition, it allows you to search for inactive users (users who haven't login in a while) and perform some bulk operation.
ramji_bitbucket August 27, 2019
   I do not have Atlassian crowd integrated , can I still use this script ? or is there anyway to generate the list of inactive users in my jira without crowd  services.
Ramji
Henning Tietgens
December 15, 2019
The script doesn't need an explicit crowd integration, it's meant for a pure Jira installation. The CrowdService class used by the script is part of Jira.
Yampalla Srinivas January 14, 2020
@Henning Tietgens
could you please help me , how to add an attachment to the mail?
we are using below script for sending a mail:
import com.atlassian.mail.Email
import com.atlassian.mail.server.SMTPMailServer
def emailSubject="test mail"
def emailBody="test mail body"
def emailAddress="yampalla.srinivasareddy@gmail.com"
SMTPMailServer mailServer=ComponentAccessor.getMailServerManager().getDefaultSMTPMailServer()
if(mailServer){
Email email=new Email(emailAddress)
email.setSubject(emailSubject)
email.setBody(emailBody)
mailServer.send(email)
Henning Tietgens
January 14, 2020
Try something like this
import com.atlassian.mail.MailException
import com.atlassian.mail.MailFactory
import com.atlassian.mail.queue.SingleMailQueueItem
import javax.activation.DataHandler
import javax.mail.BodyPart
import javax.mail.Multipart
import javax.mail.internet.MimeBodyPart
import javax.mail.internet.MimeMultipart
import javax.mail.util.ByteArrayDataSource
Multipart mp = new MimeMultipart("mixed")
BodyPart attPart = new MimeBodyPart()
// take care to set correct mime type for the attachment
ByteArrayDataSource attBds = new ByteArrayDataSource(data, 'text/plain; charset=utf-8')
attPart.setDataHandler(new DataHandler(attBds))
attPart.setFileName(attachmentFileName)
mp.addBodyPart(attPart)
def mailServerManager = ComponentAccessor.getMailServerManager()
def mailServer = mailServerManager.getDefaultSMTPMailServer()
if (mailServer && !MailFactory.settings.isSendingDisabled()) {
Email email = new Email(emailTo, emailCC, emailBCC)
email.setMultipart(mp)
email.setFrom(mailServer.getDefaultFrom())
email.setSubject(config.emailSubject)
email.setMimeType(config.emailMimeType)
email.setBody(config.emailBody)
try {
SingleMailQueueItem item = new SingleMailQueueItem(email)
ComponentAccessor.getMailQueue().addItem(item)
catch (MailException e) {
log.error("Error sending email", e)
} else {
log.warn("No mail server or sending disabled.")
Yampalla Srinivas February 4, 2020
@Henning Tietgens
Thanks a lot for your help, it is working.
