How to get issue count using JQL in jira?
Nagaveer
I need to get issue count based on filter using JQL.
for ex.
filter-> project in(ADMIN,MANGMNT) AND "Name" ~ "admin"
JQL needs to be used through REST API.
please help
11 votes
Andreas Ebert
June 11, 2014
There is no REST resource that returns ONLY the count, but you can use /rest/api/2/search?jql=YOUR_JQL_QUERY and then look at the result object. It will contain an attribute "total" which is the count you want.
Straight from the api doc:
    "expand": "names,schema",
    "startAt": 0,
    "maxResults": 50,
    "total": 1, // <- you want this value
    "issues": [
            "expand": "",
            "id": "10001",
            "self": "http://www.example.com/jira/rest/api/2/issue/10001",
            "key": "HSP-1"
Ofer Prat October 25, 2017
Bill Cowden
July 19, 2018
Setting "maxResults=0" only returns the metadata without the rows if you're only interested in the total:
rest/api/2/search?jql=project=YOUR_PROJECT&maxResults=0
Like # people like this
Matt
Nice, thanks Bill
Hugo
Thanks a lot Bill!!!
Bilal Khan November 13, 2023
Nice, thanks Bill (3)
13 votes
Jose Ramirez
Is there an straight JQL equivalent for this ?
3 votes
Robert_Hall
April 16, 2020
Well you can could just do a normal JQL  query
issuetype = 'Test' and TestRunStatus = "pass" and assignee = <UserName>
Then tools will give a count for the query
A bit of a bodge but does tell you what you need to know
Nethra
March 16, 2021
This has a limitation, it will not show the actual count for entries more than 1000.
Like bennoll likes this
Jesse Rivera
May 20, 2021
The best way I have found, using Zephyr Jira is to use the options under Export, inside the Filters page.
Once you have created your jql query, Click on Export, you will see the Print list option.
Clicking on Print List will open a new tab with the same list from the last page.
It will also give you this line:  – ### of ### as at: Day/Month/Year Time.
That ### is the number you are looking for.
Print List Option:
Printed List:
Nic Brough -Adaptavist-
June 11, 2014
Save the filter and look at it - most of the ways of viewing a filter will give you totals.
Note that JQL is NOT SQL, and it doesn't have anything to say about the results it pulls back. All it does is give other parts ofthe system list of issues to work with.
Nagaveer
Thanks Nic.
Would you suggest an alternate way to get only count via any REST API method?
Like Sakthivel likes this
June 11, 2014
Run the filter and then write some code that adds up the totals in whatever application is you've written the REST code into
philubert
Add this onto your JQL to get the count (assuming you have Adaptavist ScriptRunner):
issueFunction in aggregateExpression("count", "reporter.count{it}")
Smita May 3, 2020
Execute a CURL command for your project specifically like this on command line and pipe more. The first line shows "total" issues in your project
e.g
COMMAND
D:\curl -D- -u username:password -X GET -H "Content-Type: application/json" http://localhost:8081/rest/api/2/search?jql=project='ABC' | more
OUTPUT
100 501k 0 501k 0 0 501k 0 --:--:-- --:--:-- --:--:-- 892k
{"expand":"schema,names","startAt":0,"maxResults":50,"total":219,"issues":[{"expand":"operations,versionedRepresentations,editmeta,changelog,renderedFields"
namrata singhal
July 17, 2020
I need to get the record count and then show it on confluence - is this possible?
Anders Dyhrberg
You are in luck @namrata singhal for confluence this is built in.
1: When editing add "Jira Issue/Filter"
2: After you have made your filter. Select "Display Options" and the "Total Issue Count"
Lawrence
Is there a way to change the font type/size of the displayed count in confluence?
Marc Isikoff
This is the issue we are having: We want to find possible duplicates based on a custom field.
We can implement the above in Confluence, but we cannot give it a form response for the custom field; Jira has no JQL scope for outside of a single issue.
And we cannot use the Marketplace so we are looking everywhere for JQL or Confluence solution for entering a value and getting a count back when basing the custom field value against "the field".
swati_dave
February 18, 2020
If you want to get issue count output you can setup query using generate api
for example if you want project base issue count then you can apply this rest api for that
URL :- "/rest/gadget/1.0/stats/generate.json?projectOrFilterId=jql-ORDER+BY+created+DESC&statType=project&includeResolvedIssues=true&sortDirection=desc&sortBy=total"
Hear in "projectOrFilterId" you can set your jql query and "statType" as like a groupBy.
Srot Sinha
October 3, 2020
I need to count of tickets for each project. I tried above mentioned API but it's returning me error
Invalid JQL query specified for chart \'ORDER+BY+created+DESC\'
I tried with another API  wherein projectOrFilterId=jsql-create+&gt+created and I got same issue again.
API works if I give a hardcoded project id though.
