How to get parentIssueId for a sub-task with Behaviours (Script Runner)?
Tomi Kallio June 9, 2016
According to the Behaviours documentation, one should be able to retrieve the ID of the parent issue of a sub-task in an initialiser script like this:
FormField parent = getFieldById("parentIssueId")
Am I doing something wrong as parent.value is always null?
An open issue SRJIRA-253: Cannot get parentIssueId value seems to perfectly capture what I'm experiencing. There are no comments on that issue or any other hints about what could be going wrong. Any hints or pointers would be highly appreciated.
I'm using Script Runner 3.1.4 on JIRA 6.4.1.
adammarkham
June 9, 2016
What you have above won't work in an initialiser but if its attached to a field it will work. Please see the answer here: https://answers.atlassian.com/questions/17894295
You can use:
underlyingIssue.parentId
Or to get the full issue object use:
underlyingIssue.parentObject
Somehow this was not easy to grasp from the documentation. I ended up not using the initialiser but scripts for individual fields.
