How to get program through Rest API?
Ashvik Mohan March 20, 2018 edited
how to add a program through api and get program detail from Rest API? Program is actually used in tempo account, if i want to get data through REST API then how we can do it?
Nic Brough -Adaptavist-
March 20, 2018
The REST API does not have functions for adding programs.
thanks Nic for your help, But Can i get program data through REST API?
March 21, 2018
Depends on what you mean by "program data".  The REST APIs serve up a lot of stuff.  You need to be specific
Ashvik Mohan March 21, 2018
i want data of tempo team program through API access.Screen Shot 2018-03-21 at 6.05.15 PM.png
March 21, 2018
Ashvik Mohan March 29, 2018
In above link their is nothing which return me only program screen data. would you help me to find that how to get only program screen data through rest api as result as json.
March 30, 2018
I'm not sure what you mean by "program screen data" - I get the tempo data back when I try it.
