Hi Everyone,
As title, How do I get the sprint start date using Behaviours? Is it possible? Thank you very much!
Best Regards,
Kris
Below code might help. But, bear in mind that an issue can have multiple sprint values, and this script returns the date of first sprint.
Sorry that I was not able to test the code, but it would guide you to a running version ;)
def sprintCf = customFieldManager.getCustomFieldObject(10000) // id of Sprint customfield
return issue.getCustomFieldValue(sprintCf)?.startDate?.first()?.toDate()
Thanks for your answer. However, It showed an error which is "issue is not undeclared". How should I fix this error? Thank you very much!
Best Regards,
Kris
Even I changed it to underlyingIssue, it will also show there is no property for startdate. Please help me on it. Really appreciate!
Hi Kris,
Ignore that error and try to run the code.
Groovy is a dynamic scripting language in which you can code without defining static types.
Happy to help :)
Hi @Tuncay Senturk ,
Sorry to bother you again,
Do you know how to get sprint start date using script field? Thank you very much!
Best Regards,
Kris
No worries!
It should be the same way actually
Is there any way which can fill up the value I caught from the script automatically without any transition? Thank you very much!
Best Regards,
Kris
Hi @Kris Han
No worries, you're not bothering at all.
You can use the same code in anywhere (scripted custom field, scripted post function, behaviors, even in listeners).
For instance you can implement your own scripted listener in which you can listen to any issue change and pick Sprint start date and do whatever you want. Only one or two lines might be added to your script accordingly.
I copied the entire script to Listener but I got lot of errors. Could you help me to give me some example? Thank you very much!
Best Regards,
Kris
You need to provide more info regarding your demand.
But you can use below code to start
def issue = event.issue
def sprintStartDate = issue.getCustomFieldValue(sprintCf)?.startDate?.first()?.toDate()
// then use this sprintStartDate on whatever you want to do.
Today only! Share what you’re the most excited about for Team ‘25 or just dance out the beginning of a new quarter with us.
Comment the postOnline forums and learning are now in one easy-to-use experience.
