I've got the URI
when I call the method getGadgetURI() with a PortletConfiguration-Instance.
As you can see, it is leading to gadget.xml. How can I get the filter that is defined in the gadget? Can you get it by Java Code?
There's a lot more information on the question this duplicates: https://answers.atlassian.com/questions/311261/get-filter-from-gadget-get-gadgets-from-dashboard
