How to get the Summary of the Issue Using JQuery or JavaScript?
ARUN KUMAR MK
June 23, 2017
If I use the below code i am able to get the Issue Key, but i need to fetch the summary of the issue in js.
        issueKey = JIRA.Issue.getIssueKey();// For Getting Issue Key
mfabris
June 23, 2017
Try this, it will work
function getSummary() {
var key = this.JIRA.Issue.getIssueKey();
var summary;
     AJS.$.ajax({
        url: "/rest/api/2/issue/" + key,
        type: 'get',
        dataType: 'json',
        async: false,
        success: function(data) {
            summary = data.fields.summary;
     return summary;
getSummary();
I am sure there is an easier way, but this surely works
Happy weekend!
ARUN KUMAR MK
June 23, 2017
I have already used this api to get the summary, but i thought there is some easy way to get it. Anyway's thanks for your reply.
Nic Brough -Adaptavist-
June 23, 2017
Not tried getSummary() yet?
ARUN KUMAR MK
June 23, 2017
Tried and not working, it not present in JIRA.Issue
Register here ⬇️
