import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.fields.CustomField;
def issue = ComponentAccessor.getIssueManager().getIssueByCurrentKey("DC_CM-1893");
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(10731L);//customfield id
def appt = getFieldById("customfield_10729")
if(issue.getCustomFieldValue(customField) =~ 'JIRA')
appt.setHidden(true);
else
{ appt.setHidden(false);
We use the above script. In the above code the validation works with existing issue " DC_CM-1893".
Whereas we need to use the behaviour for current issue in create screen.
Not able to get the current issue key and apply validation.
Instead of existing issue we need the current issue which is about to create.
Please let us know how to achieve this.
You can't.
The issue does not have a key until after the issue has been created - this effectively happens in post-functions that occur after the completion of the screen.
Thanks Nic Brough,
We usually do hides the fields according to the other field values. There we don't need to mention the issue key, and it is taking automatically, whereas for the cascading select the same logic is not working. So we tried in the above script where we need the issue key.
This below script is working for normal select list and text field, but not for Cascade select list.
def Virtual = getFieldByName("Virtual Team") def prcd = getFieldByName("Proof of Concept Driver") log.debug("Virtual" + Virtual.getValue())
if (Virtual.getValue() =~ "Product Path")
prcd.setHidden(false);
prcd.setRequired(true);
else
prcd.setHidden(true);
prcd.setRequired(false);
Please help.
