How to get the custom field value using by groovy script?
Deleted user March 15, 2016
Hello
I want to get a value of customfield using by groovy script..
And then, I want to set a prefix on issue summary using by customfield value..
it is an example below;
  • custom field name = 'Test Field' (single select list field type)
  • custom field name value = 'apple'
Then first of all... I want to get the value what is 'apple' by groovy script.
and next i want to set a summary..
Actually I know setting a summary by groovy like below
    issue.setSummary("Test Summary");
Then it will be set a "Test Summary" as a new issue summary..
However what I want to do is "issue.setSummary(customfieldvalue + summay)"
So...How can I get a customfield value (single select list field type) and how can set a summary..?
Additionally.. I will set it by post-function..
Please let me know.. thanks..
17 votes
Tuncay Senturk
Can this help?
def issueManager = ComponentAccessor.getIssueManager()
def cField = customFieldManager.getCustomFieldObject("customfield_id")
def cFieldValue = issue.getCustomFieldValue(cField)
 issue.setSummary(cFieldValue + " " + issue.summary);
JamieA
March 15, 2016
Last line should probably be:
Tuncay Senturk
My bad, copy paste smile
I changed the code accordingly
Deleted user March 16, 2016
I tried below;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.Issue;
def cField = customFieldManager.getCustomFieldObject("10304")
However it was not working..
I think they have some problem but I don't know why..
ahhh.....
it was it..
def cField = customFieldManager.getCustomFieldObject("customfield_10304")
However what I told about customfield type was "Selecet List" type..
It works from "Text Field" but I think it doesn't work from "Select List" Type..
Like Liudvikas likes this
I solve it..
Thanks to Tuncay Senturk and Jamie Echlin.. smile
Also if you don't mind, can you recommend some of sites to learn groovy script?
ANN LEE July 21, 2016
By following the previous example to get customer field (single line text) value. But still fails!
Could you please let me know? Many thanks!
def firstnameTypeCF = customFieldManager.getCustomFieldObject("First Name")
def firstnameFieldV = issue.getCustomFieldValue(firstnameTypeCF)
def lastnameTypeCF = customFieldManager.getCustomFieldObject("Last Name")
def lastnameFieldV = issue.getCustomFieldValue(lastnameTypeCF)
issue.setSummary(summary + " - " + firstnameFieldV + " " + lastnameFieldV)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2016-07-21 10:39:21,458 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2016-07-21 10:39:21,458 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: TPSHR-1038, actionId: 1, file: <inline script>
java.lang.NullPointerException
	at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:896)
	at com.atlassian.jira.issue.Issue$getCustomFieldValue$3.call(Unknown Source)
	at Script104.run(Script104.groovy:72)
Thanos Batagiannis [Adaptavist]
April 6, 2017
Hi Ann,
The
ComponentAccessor.getCustomFieldManager().getCustomFieldObject("First Name")
get as a param the String representation of the custom field's id, should be something like, customfield_12345
So either you have to pass as a param the id or if you want to use the name try
// be aware if you have more than one custom fields with the same name
ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Name of the custom field")
Naveen April 25, 2018
Hi @[deleted]
How did you solve the Single Select List  Custom field issue that you were having above?
As you mentioned i could able to extract out Text Field Value but not Single Select List field value. How did you got the value for that field, could you please post here.
Tuncay Senturk
You can use below line.
((LazyLoadedOption)cFieldValu).getValue()
here is the import line
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption;
Like Szpecku likes this
Naveen April 26, 2018 edited
Thank you @Tuncay Senturk, i am very bad at coding, i am using it like below, but it is throwing an error, please correct me
def cField = customFieldManager.getCustomFieldObject("customfield_12512")
def cFieldValue = ((LazyLoadedOption)cField).getValue()
if (cFieldValue == "Stream Creation")
issue.summary = "Stream request has been Submitted"
Naveen
Tuncay Senturk
def selectedValue = ((LazyLoadedOption)cFieldValue).getValue()
if (selectedValue.equals("Stream Creation")) {
// do anything here
Ok thank you again :), i will try this and let you know how it goes.
@Tuncay Senturk
That did the trick, thanks a lot for all the help, greatly appreciated !!!
Tuncay Senturk
Glad to hear that.
Tuncay Senturk
By the way, do not forget to check nulls.
if (null == cFieldValue) return;
// and also hard coded string should be put before the equality, as below
if ("Stream Creation".equals(selectedValue)) {
// do anything here
@Tuncay Senturk
Sure, will do, thanks alot !!!
Tuncay Senturk
You're welcome ;)
Lotus Support June 13, 2017 edited
Using code i am getting error
huw May 2, 2018
Alejandro Suárez García
or
def cField = customFieldManager.getCustomFieldObject(10304L)
Like 2 people like this
Also, I imported all required libraries at the very beginning of this script:
Register here ⬇️
