How to get the projectID in velocity templates (*.vm)
Adria Alonso
October 8, 2019
I'm working on a custom Release Notes and I facing the following issue:
  • I have to create a link in the releasenotes.vm file and I need Version Id and the project id.
  • To get Version id It was pretty fast, but I cannot figure out a way to get the project id, $project returns its name, i've been testing but without no luck
#set($ver = $versionObj.id)  works perfelcty
What is needed to retrieve the same for the project?
Thank you
Tuncay Senturk _Snapbytes_
Hi @Adria Alonso
It depends on the context. If on server side you put versionObj to the context you can use below samples to get projectId
#set($projectId = $versionObj.projectId)
or
#set($projectId = $versionObj.project.id)
 I hope it helps
Adria Alonso
October 9, 2019
works like a charm!
Thank you
Glad that it works :)
Like Adria Alonso likes this
