Hi All,
we have a project with more than 400 issues and we need to make a report which shows the time spent in 'Clarification' status for each issue.
How can we do that?
I know that there is the Transitions tab on the issue view but we need a report for all the issues of the project.
We use version 5.1.2 Jira
Can you please help?
Thanks in advance,
Rumi
Use Jamie's Script Runner Plugin, add a Scripted Field and modify and user code from https://studio.plugins.atlassian.com/wiki/display/GRV/Scripted+Fields#ScriptedFields-TotaltimethisissuehasbeenInProgress
I have a similar question, see https://answers.atlassian.com/questions/309076/script-to-calculate-time-since-created-date
It is possible with Timesheet add-on for JIRA, using own filter. The add-on provides timesheet reports and gadgets.
This plugin provides a gadget to display "Average Time in Status" which may be of some use to you. But still lacks a report.
https://studio.plugins.atlassian.com/wiki/display/JCHART/JIRA+Charting+Plugin
Hi Rumi,
You can create a "Time Tracking Report". You have the option to export to excel and you can then filter issues in a particular status
you're right but most of the issues are already in a different status: so the issues concerning were/are in that particular status.
