I am using query issue custom fields (Multi linking fields), so that i get all the issues resulted by by jql and select any of them for my customfield.
So my jql requirement goes as below:
project = <prjName> and issuetype != <issueTypr> and issue in linkedIssues("%currentkey%")
But i am unable to get the currentkey value in there, and my jql fails. Is there any way to get the current issue-key in the jql.
Any default variable provided by the JIRA for the current issue-key.
Any help would be appreciated.
I do not know a solution with standard JIRA functionality.
But Plugin "Script Runner" includes a JQL function linkedIssuesOf(Subquery, [link name])
By that you might define a subquery in a way to get your current issue.
