I am trying to fetch issue data using c# code.
I have installed Atlassian SDK of version 2.2.0. I am able to connect JIRA and fetch data using "GetIssuesFromJql()" function.
Issue data is coming fine but time-tracking or original estimate data is missing.I am not able to see such field in the issue i am receiving.
Could someone please help me getting mentioned issue data using c#.
Actually I solved this now with Atlassian.SDK v10.5.0
the following code below, helps me determine if i need to create a specialised CreateIssueFields. This is neccessary as part of the CreateIssue() if you want to initially setup correctly the Original Estimate.
private CreateIssueFields NewIssueCriteria(string project, RallyDefect item, string parent)
CreateIssueFields res = null;
if (item.PlanEstimate > 0)
res = new CreateIssueFields(project)
ParentIssueKey = parent,
ProjectKey = project,
TimeTrackingData = new IssueTimeTrackingData($"{item.PlanEstimate:##}d", null)
return res;
USAGE
var createFields = NewIssueCriteria(pKey, item, null);
var i = jira.CreateIssue(createFields);
I also used: when i wanted to setup the "story point estimate" field. make sure this is on your screen before using it.
SetCustom(ni.CustomFields, "Story point estimate", $"{story.PlanEstimate:#}");
void SetCustom(CustomFieldValueCollection customs, string field, object value)
if (value == null)
return;
if (customs[field] == null)
customs.Add(field, value.ToString());
else
customs[field].Values = new[] { value.ToString() };
I usually use the REST API but have just started looking at the SDK. You mention version 2.2.0 (circa 2013), whereas I have just installed (via NuGet) version 10.0.2, which is a huge leap forward. The documentation is https://bitbucket.org/farmas/atlassian.net-sdk/wiki/Home and there is mention of worklogs etc., so possibly look at this
Thanks @Warren for the suggestion.
I tried using latest NuGet package but still No Luck. I am not able to get Efforts(original estimate ) data in the issue.
Could you please suggest on efforts data?
me neither!
any help on this would be greatly appreciated guys!!!!
Firstly, are you on server or cloud?
Secondly, whilst I said I was looking at the SDK, I've never actually used it, because the REST API has always managed to give me what I want.
So ... having answered my first question, what are you actually trying to do? Do you have some C# code working for simple queries but want to get worklogs? Or are you just starting?
I am using the Atlassian.SDK (10.5.0), along with Tempo, and using JIRA Core in the cloud.
basically, im converting Rally Stories/Defects into JIRA, but I cant seem to find the best way to set the Original Estimate for the story.
I've tried to use :
issue.AddWorklogAsync("0h 1m", WorklogStrategy.NewRemainingEstimate, "3d").Wait();
but this does not update the Original Estimate.
I'd like to see the original estimate being set when i create the story, I understand now the AddWorkLog is for when your altering the timeline once the story started.
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
