×Hi
An internal audit pointed out that the Version is exposed in Response header and Metadata for the Jira system.
So I tried to hide this, "Hiding the Jira version number from page markup" method, but it didn't work. Is there any other way?
That's the information I want to hide.
<meta name="application-name" content="JIRA" data-name="jira" data-version="7.13.18">
<meta name="ajs-version-number" content="7.13.18">
<meta name="ajs-build-number" content="713018">
Hi @Jaewoong Choi ,
in order to do that you need to follow this guide https://confluence.atlassian.com/jirakb/hiding-the-jira-version-number-from-page-markup-1056673381.html
Ciao,
Fabio
I've already tried the way you told me. But it didn't work. That's why I asked if there was another way.
Eventually, I decided to process it with the script below.
AJS.$("meta[name='application-name']").remove();
AJS.$("meta[name='ajs-version-number']").remove();
AJS.$("meta[name='ajs-build-number']").remove();
Footer has already taken action.
What I want is that when I look at the page information using Dev tools in the browser, I don't see the information below.
Hi @Jaewoong Choi ,
please could you post that page? I need to explore it in order to figure out how to hide those elements.
Fabio
Please check the example page below.
After all, what I want to do is to make the following values invisible to the user or remove them from the Response Header value or Browse's Dev Tool.
<meta name="application-name" content="JIRA" data-name="jira" data-version="$JiraVersion">
<meta name="ajs-version-number" content="$JiraVersion">
<meta name="ajs-build-number" content="$JiraVersion">
Hi @Jaewoong Choi ,
you need to add the following code in the Announcement Banner :
<script>
jQuery().ready(function() {
jQuery("#footer").hide();
</script>
Hope this helps,
Fabio
