×Hi,
We don't want to show the assignee and reporter information to external customers. In release 4.3, we added a test in the file atlassian-jira/WEB-INF/classes/templates/jira/issue/block/peopleblock.vm.
This file doesn't exist anymore in release 4.4.
Does somebody knows where this panel is configured now?
Stéphane
For anybody finding this question on a newer version of JIRA: Starting in JIRA 5, the side panels are just regular old plugins. Go to plugins in Administration and then click "Show System Plugins". Look for "Atlassian JIRA - Plugins - View Issue Panels" and expand it. Expand "Manage plugin modules" and then disable the "peoplemodule". This will remove the panel entirely. You can turn off pretty much every single panel on the View Issue screen here.
This also works great if you want to make your own version of that panel (modify/add/remove elements). Just disable the official one and create a modified version in your own plugin. You should obviously merge in the official one as it changes, but this is a lot more self contained than worrying about modifying live vm files in your install.
In order to hide the reporter, assignee and timetracking information, I had to change the following files :
templates/jira/issue/field/reporter-columnview.vm,
templates/jira/issue/field/timetracking-view.vm,
templates/jira/issue/field/assignee-columnview.vm,
templates/jira/issue/field/reporter-view.vm,
templates/plugins/jira/issuetabpanels/changehistory.vm,
templates/jira/issue/field/assignee-view.vm
what changes did u apply how can i change mine too thx in advance
