We have a list of labels but, there is a group that we want to hide (disable) so that they are not eligible
This is possible that?
Thank
Hi @Silvana Hernandez, I don't think this is possible with the "Labels" field. This filed will accept any user input - including bad labels and misspellings! So the flexibility of this field is both great and terrible depending on your use case. :)
Instead, if you want to control selection values, I recommend using a custom field of type "Select List (single choice)" or "Select List (multiple choices)" instead.
Hope this helps!
Rachel Wright
Author, Jira Strategy Admin Workbook
