How to implement command line interface methods in jira-soap plugin
mihan ayeshana June 4, 2012
This is the method use to update Issue Type Scheme in jira command line interface
public void setIssueTypeScheme(final RemoteProject project, final String schemeId) throws ClientException, RemoteRestException, RemoteException {
String request = "/secure/admin/SelectIssueTypeSchemeForProject.jspa";
Map<String, String> parameters = new HashMap<String, String>(); // this handles encoding etc...
parameters.put("projectId", project.getId());
parameters.put("schemeId", schemeId);
getGuest().restRequest(request, parameters);
// TODO - might need to do more error checking? Default error handling might be enough
How can i implemet this method in jira-rpc soap plugin. Becuse getGuest().restRequest() is defficult to implement in plugin. so i want to know there exits any eacy way to do it.
Bob Swift
June 4, 2012
Not sure what you are trying to do, but it is not a SOAP API. And there is not a REST API for this either. So what is done is a workaround.
Jira 4.3.3 jira-soap client plugin not supporting for update Issue Type Scheme so im tring to create a method in plugin to that. but i cant find a way to do it. Command line interface is also not working. It gives
Remote error: '10020' not found as Issue Type Scheme
Pleace tell me way to do it
Help us plant more trees
