How to import a Workflow into a JIRA Cloud application?
Prayuja Patil
I want to import jira server workflow into cloud instance.
Deleted user May 22, 2018
Hi @Prayuja Patil,
Unfortunately it is not possible to directly import however there is a workaround documented if you have not already found it.
Hope this helps
Prayuja Patil
Hi @[deleted],
No other workaround in JIRA itself??
Unfortunately, I could not find any other documentation around this subject without compromising the workflow's confidentiality.
The only other method, I found, would be to upload your workflow to the Atlassian Marketplace, however the workflow would become available to the public. Your cloud instance could then search and import the workflow from the Marketplace.
Help us plant more trees
