How to import com.atlassian.jira...
Alexander
I'm trying to create a custom groovy listener.
First of all, I created groovy class:
package com.custom
import com.atlassian.jira.event.issue.AbstractIssueEventListener;
import com.atlassian.jira.event.issue.IssueEvent;
class MyListener extends AbstractIssueEventListener {
    void issueUpdated(IssueEvent event) {
        // code
And now, I'm trying to compile it with groovyc. I got these errors:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
MyListener.groovy: 3: unable to resolve class com.atlassian.jira.event.issu
 @ line 3, column 1.
MyListener.groovy: 4: unable to resolve class com.atlassian.jira.event.issu
e.IssueEvent
 @ line 4, column 1.
How can I make it work?
JamieA
January 26, 2015
You'll need to set a massive classpath, but you should not need to compile it. Just point the "custom listener" at the .groovy file, and it will handle compiling.
Alexander
thank you Jamie for a quick answer. But how can I point the custom listener at the groovy file if in jira, as I see, I need .class file? Or what I did wrong to make a custom listener? I put .groovy file ...WEB-INF/classes/com/custom/MyListener.groovy. And inscript runner in creating a custom listener in field: name of groovy class I cannot find it. And in jira administration where listeners, I cannot find it too.
JamieA
January 26, 2015
What version of jira and the plugin are you using?
Alexander
jira 6.3.8, script runner plugin 3.0.7.
Alexander
I created empty file hello.class in /WEB-INF/classes/com/custom/ and then I can see him as a listener, so how can I compile my first MyListener.groovy in MyListener.class? I tried groovyc and nothing good, as you see. Set a massive classpath isn't good solution. Now, I'm trying to do it with Intellij, but I met a problem: idea doesn't understand imports with com.atlassian.jira. ... And I dont know how to add it. Can you help me please, Jamie?
Alexander
but you said I dont need to compile .groovy, what should I do to make it visible in "groovy class name" field?
JamieA
January 26, 2015
Use Custom Listener, and you put the .groovy file under one of your script roots, eg <jira_home>/scripts, in the correct directory according to its package.
