×I am unable to import Comments using CSV importer tool ?
is there a way i can include comments /attachments and images.please help
Hello Tummala,
Which importer tool are you using? You can do this using the Importer Tool in the JIRA Administraiton menu. To do this, you would need separate columns for your comments and attachments (and your JIRA server would have to have access to the http/https location that the attachment is located.) Here are the instructions:
https://confluence.atlassian.com/display/JIRA/Importing+Data+from+CSV
Good luck!
