We have requirement where the issues from Scrum Jira board has to be copied to Kanbo , Can anyone let me know if we have any script which helps to perform this .
Suma
I assume you mean KanBo - which is a separate platform?
If yes, I've not seen a Marketplace App that does this - I'd consider looking for...
Note: I know it's possible to use a middleware, send issues via API, and export to CSV from Jira. I'm not sure on the opposite end how to get these into KanBo - you'll need to do that research separately :)
Ste
Thank you for the info, I will try to do some research on it..
