How to import testcase in JIRA(from CSV) and what would be proper format of CSV file
Bimleshsharma February 17, 2019
I was trying to import my testcases that was in csv format, i had 4 columns say Desc, Steps, Expected result and assignee but i am facing different issues.
Bimleshsharma February 21, 2019
What happened , there is no response after providing screenshots?
Milan Chheda [INFOSYSTA]
February 18, 2019
Are you using Zephyr and importing testcases using the same? Or Are you importing in an issue type having custom fields as Steps, Expected result?
Also, can you share the error message or screenshot as that would help understand the problem better.
Bimleshsharma February 20, 2019
Screenshot 2019-02-20 at 2.39.02 PM
February 23, 2019
That usually means the second line is empty. Either it genuinely is, or you have ended the first line with something that it cannot handle. Also, check which delimiter is used in the csv and make sure, that you choose that delimiter while importing the issues.
Deleted user February 17, 2019
Hi @Bimleshsharma ,
Hope you have gone through the documentation page. The error might be related with date format or might be other, please try once again and check the log file.
Kishore Kumar Gangavath.
Hi I tried with below template of csv.
Summary, Assignee, Reporter, Issue Type, Description, Priority
"Test issue", Bimlesh Sharma, Bimlesh Sharma, 5, This is description ,
Imported csv with following steps.
CReated Testexecution task
Test => testcase imported.
Added csv file and click on Next and i got below error.
Second line (after header row) in CSV file is blank
Read the story
