I'd like to edit the XML of a workflow. I can export it, edit it, and then import it, but this requires me to create a new workflow. Is there any way to import and overwrite a draft of an existing workflow?
That's not possible. The only option is to modify it directly in the database.
After I update the xml in the database, should I restart the service? I'm trying to set the resulting state of a global transition to -1 but it's not sticking. This is for a "restricted edit" type function.
