How to inherit one custom field value to another custom field
mokkapati naveshchowdary April 9, 2019 edited
For example I had fix versions field in two different issues like story and sub-task in same project,so what we entered in Story should come to Task
Taranjeet Singh
@mokkapati naveshchowdary You will need to use a 3rd party add-on like "Jira Miscellaneous Workflow Extensions" to achieve this. The specific workflow post-function provided by this add-on that you can use in the workflow of your Sub-task issue type is "copy field value from parent issue": https://innovalog.atlassian.net/wiki/spaces/JMWE/pages/68878488/Copy+field+value+from+parent+issue
NOTE: This is a paid add-on for JIRA Server.
Hope it helps !
Is there any possibility to solve by using JSU??
Taranjeet Singh
@mokkapati naveshchowdary You can also solve this use case by using the below post-function from "JSU" in your Sub-task issue type workflow:-
https://confluence-apps.beecom.ch/display/JSU/Copy+Value+From+Other+Field+Post-Function
Hope it helps !
Help us plant more trees
