Jira version: 7.13.0
Java version: 1.7
Platform: server
I need to receive SearchResultsBean to get Issues like JSON.
When I started Jira I catch the exception:
The plugin has been disabled. A likely cause is that it timed out during initialisation. It has the following missing service dependencies : &issueBeanBuilder2 of type(&(objectClass=com.atlassian.jira.rest.v2.issue.IssueBeanBuilder2)(objectClass=com.atlassian.jira.rest.v2.issue.IssueBeanBuilder2))
my service:
@Named
@ExportAsService({IIssueJiraService.class})
public class IssueJiraService implements IIssueJiraService {
private final IssueBeanBuilder2 issueBeanBuilder;
@Inject
public IssueJiraService(@ComponentImport IssueBeanBuilder2 issueBeanBuilder) {
this.issueBeanBuilder = issueBeanBuilder;
public ResultsBean getIssueBean(issue){
IssueBean issueBean = issueBeanBuilder.build(issue);
List<IssueBean> issueBeans = Arrays.asList(issueBean);
SearchResultsBean resultsBean = new SearchResultsBean(0, 1000, results.getTotal(), issueBeans);
return resultsBean;
my pom (only dependency for IssueBeanBuilder2):
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-rest-plugin</artifactId>
<version>7.1.0-QR20151229171111</version>
<scope>provided</scope>
</dependency>
Jira docs:
https://docs.atlassian.com/software/jira/docs/api/8.1.0/com/atlassian/jira/rest/v2/search/SearchResultsBean.html
https://docs.atlassian.com/software/jira/docs/api/8.1.0/com/atlassian/jira/rest/v2/issue/IssueBean.html
You should be able to inject BeanBuilderFactory and then call its newIssueBeanBuilder2 method.
I understand that you are getting a plugin disabled message when trying to start this plugin. While I don't have much experience in terms of developing plugins for Jira, I did notice that you listed the Java version as 1.7. The problem with that, if accurate, is that Jira 7 and higher has required Java 8 (aka 1.8) at least since Jira 7.0.x versions. More details on this JVM requirement can be seen in the Supported platforms documentation.
If that is not the solution, then I would recommend asking within our Developer Community. That community is technically a separate site from this one, and it is geared more towards plugin development for Atlassian products. So perhaps you might find additional help there.
Andy
Hi, @Andy Heinzer
Thanks for your help
I tried to switch to java 1.8 and its not the solution. Also, I asked on Developer Community and we came to the conclusion that its impossible.
Therefore, I abandoned this approach and use java classes from Jira.
Oleksii
