I'm trying to get the version number of my plugin to be equal Jenkins BUILD_NUMBER environment variable.
Plugin is built inside docker container using command:
docker run --rm --volume $PWD/src/jira_plugin/:/opt/atlas/ codeclou/docker-atlassian-sdk:latest atlas-package
POM.xml:
<project>
<version>${jenkins.buildNumber}</version>
<properties>
<jenkins.buildNumber>${env.BUILD_NUMBER}</jenkins.buildNumber>
</properties>
</project>
Result:
[INFO] Building jar: /opt/atlas/target/test-null.jar
..[ERROR] Failed to execute goal
com.atlassian.maven.plugins:maven-jira-plugin:6.3.15:generate-obr-artifact
(default-generate-obr-artifact) on project test:
Source '/opt/atlas/target/test${env.BUILD_NUMBER}.jar' does not exist
Nevertheless command
echo `printenv`
in docker correctly displays BUILD_NUMBER.
Question:
What should I add in pom.xml to inject BUILD_NUMBER var in pom.xml and to display version correctly?
Any help would be greatly appreciated.
I figured it out:
docker run -e BUILD_NUMBER="${BUILD_NUMBER}" ...
So the variable will be injected and can be used in pom.xml.
