How to insert dynamic table in script fragment/web panel
nallu July 17, 2018
In JIRA, I am trying to create a Web Panel which will display the linked epics details in HTML format as below,
KeySummaryStatusTypeFix-Version
JIRAKey-123Linked Epic - 1NewEpic[Label-test]
I referred below sites and did this,
Advanced Scripted Field - https://scriptrunner.adaptavist.com/latest/jira/recipes/misc/table-custom-field.html
Web Panel - https://scriptrunner.adaptavist.com/latest/jira/fragments/WebPanel.html
Here is my code. It doesn't display the content in Issue View screen.
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import groovy.xml.MarkupBuilder
Issue issue = context.issue as Issue
//Get current Key
def currKey = issue.getKey()
//Query for all epics where feature link = current key
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def issueManager = ComponentAccessor.getIssueManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getUser()
def queryString = 'type=epic and "Feature Link" = ' + currKey
def query = jqlQueryParser.parseQuery(queryString)
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter())
StringWriter writer = new StringWriter()
def xml = new MarkupBuilder(writer)
if(!results){
"N/A"
xml.style(type:"text/css",
#scriptField, #scriptField *{
border: 1px solid black;
#scriptField{
border-collapse: collapse;
th, td {
padding: 5px;
text-align: center;
xml.table(id:"scriptField"){
tr{
th("Key")
th("Summary")
th("Status")
th("Type")
th("Fix-Version")
results.getIssues().each { documentIssue ->
tr{
td(documentIssue.key.toString())
td(documentIssue.summary.toString())
td(documentIssue.status.getName().toString())
td(documentIssue.getIssueType().getName())
td(documentIssue.getFixVersions())
return (writer.toString())
Hence, I tried to display the simple content as a div. I just removed MarkupBuilder part from the above code and wrote it as simple as below.
//Get current Key
writer.write("<div style='background-color: yellow; text-align: center'>" +
" ${currKey} - Testing </div>")
In the second case, it is displaying the web-panel with data correctly as below
Can anyone look into my first code and tell me what i am doing wrong over there? I feel like, this is not working for 'MarkuuBuilder'.
Is there any other way to display the data in a simple and need HTML table.
Please help me out.
Mark Markov
July 17, 2018 edited
Hello @nallu
Im not shure that MarkupBuiler wil work too.
You can look at my example here, how to write html table and fill it with info.
If you need more detailed info, feel free to ask!
Hope it helps!
nallu July 19, 2018
Thanks a lot for sharing your code @Mark Markov
Ilya Stekolnikov
March 17, 2022
Dang Thi Thuy Tien
November 28, 2019
Christof Hurst _kreuzwerker_ August 8, 2019
I think you can just use official writer object and give xml markup as string to the write() function
