How to link Story to a Test without manual intervention?
Puneet Sapaliga
October 27, 2018
Test cases designed in Zephyr format (PFA - dummy test case documented in excel spreadsheet).
Steps:
1) Open the 'Zephyr for JIRA Importer Utility'  application on your computer
2) Enter the URL, username and password and login
3) Select the required project
4) Select 'By ID'
5) Enter the correct column numbers against the fields (name, steps, test data, etc.)
NOTE: There is no field named Story/User Story in the list of fields
After the tests are uploaded to JIRA using 'Zephyr for JIRA Importer Utility'
except user story all the other fields related to the test case are populated and visible in the JIRA issue (test).
Testers have to manually link the user stories with the tests.
This results in a lot of time and efforts being wasted.
