Hi All,
I want to link issues that same fix version automatically. For example. I have "release" and "fix" issues. Release version is V1.1. While I setting fix's version which be V1.1, I want to link both automatically. How can i do that?
Dear @Ahmet Faruk,
there is no built-in functionality like you described. You have to implement this with some scripts but this will require a commercial plugin.
So long
Thomas
