How to list users which are part of confluence-users group and an other group
serge calderara
October 1, 2024
Dear all,
I could not find out the proper to do it hpe anyone can point out to correct querry.
I have a need to list all users from confluence-users goup which belongs also to an other group A
Any idea of the correct SQL querry ?
regards
Raghavendra Reddy January 9, 2025
Hi @serge calderara ,
We use the below query in oracle DB to get the data.
SELECT cu.DISPLAY_NAME, cu.USER_NAME, cu.EMAIL_ADDRESS, g.group_name
FROM cwd_user cu
JOIN cwd_membership m ON cu.id = child_user_id
JOIN cwd_group g ON m.parent_id = g.id
JOIN cwd_directory d on cu.directory_id = d.id
WHERE g.group_name = 'confluence-users'
if you want to get the active users you can use the below one
FROM cwd_user cu
WHERE g.group_name = 'confluence-users' AND cu.active = 'T'
Sushant Verma
Hi @serge calderara
Welcome to the community!
To achieve this, you can use a query that joins the relevant tables in your Confluence database. Assuming you have tables named user_group and group_membership, here is an example of how you might structure your query.
SELECT u.username FROM user_group ug1 JOIN group_membership gm1 ON ug1.user_id = gm1.user_id JOIN user_group ug2 ON gm1.user_id = ug2.user_id WHERE ug1.group_name = 'confluence-users' AND ug2.group_name = 'Group A';
Sushant Verma
Help us plant more trees
