  • Community
  • Q&A
  • Jira
  • Questions
  • How to maintain a child-parent relationship between a Story and Task like we have bwn task & subtask
Vivek Garg
May 2, 2022
I wanted to establish a child-parent relationship between task and story as we can maintain in subtask and task.
Mohamed Adel
May 2, 2022
Hi @Vivek Garg  Welcome to the community
no extra effort required as long as you can add subTask under story then it is automatically added with Parent/Child relation linkType. similar what you are doing with Task
Mohamed Adel
Vivek Garg
May 2, 2022
Thanks @Mohamed Adel ... That is what my understanding as well but when i am creating the plan and in hierarchy selecting Feature to the subtask, it is not showing the task under the story otherwise everything else (Story under Feature, Subtask under Task) is showing correct mapping. Ex- IMG_8096.jpg
Mohamed Adel
May 2, 2022
Hi @Vivek Garg
I'm sorry I read the question wrongly , Task & Story are in the same level and you can not add one of them under the other one.
Mohamed Adel
