Sign up Log in
How to make a GET request from Jira to Confluence?
Vineet Kumar
Hi Everyone, I am able to make a POST request from Jira to Confluence with the help of this code, does any one know how can i modify the below part of the code to make a GET request from Jira to Confluence.
authenticatedRequestFactory
.createRequest(Request.MethodType.POST, "rest/api/content")
.addHeader("Content-Type", "application/json")
.setRequestBody(new JsonBuilder(params).toString())
.execute(new ResponseHandler<Response>() {
@Override
void handle(Response response) throws ResponseException {
if(response.statusCode != HttpURLConnection.HTTP_OK) {
throw new Exception(response.getResponseBodyAsString())
else {
def webUrl = new JsonSlurper().parseText(response.responseBodyAsString)["_links"]["webui"]
 @JamieA @Jamie Echlin _ScriptRunner - The Adaptavist Group_
Tarun Sapra
January 10, 2019
Hello @Vineet Kumar
What is it that  you plan to achieve by doing the Get request?
For the doing the get request you do the change here
.createRequest(Request.MethodType.GET, "rest/api/content")
And also make required changes in the response handler callback code.
Bastian Stehmann
January 10, 2019
Tarun is right, try something like this and replace PAGE_ID_HERE with the ID of the page you want to get.
.createRequest(Request.MethodType.GET, "rest/api/content/PAGE_ID_HERE")
@Override
else {
Vineet Kumar
Thanks Tarun and Bastian, I would like to GET the content of a confluence page and copy it to a variable from the Jason output, but the method is returning null on the script console, May i know which variable on the above script will hold the result in the form of Jason from which i can get the content written on the page.
Bastian Stehmann
January 10, 2019
Change
To new
def body = JsonSlurper().parseText(response.responseBodyAsString)["body"]
 then you can access the body in storage format with
body.storage.value
Sngy August 28, 2020
@Bastian Stehmann I'm using your code to make it possible for users in a Jira Service Desk to create their own Confluence Space by just filling in fields in the Service Desk.
is there any way, so that a user without admin rights can use the Rest Call in order to create a Confluence Space? is there any method in the authenticatedRequestFactory, that might make this possible?
