How to make attachment mandatory?
Swarna Radha
Hi, I have used Field(s) changed validator "attachment" but it is not making the field mandatory.
Then I have used script validator using condition below:
ComponentAccessor.attachmentManager.getAttachments(issue).size() = 0
This is not letting me submitting the form as the error message is displaying.
Is there any solution?
Swarna
8 votes
Mark Markov
August 22, 2018
Hello @Swarna Radha
You can create custom script validator to achieve this.
import com.atlassian.jira.issue.IssueFieldConstants
import com.atlassian.jira.issue.attachment.TemporaryWebAttachment
import com.atlassian.jira.issue.attachment.TemporaryWebAttachmentManager
import webwork.action.ActionContext
import com.opensymphony.workflow.InvalidInputException
def temporaryAttachmentUtil = ComponentAccessor.getComponent(TemporaryWebAttachmentManager)
def formToken = ActionContext.getRequest()?.getParameter(IssueFieldConstants.FORM_TOKEN)
if (formToken) {
def tempWebAttachments = temporaryAttachmentUtil.getTemporaryWebAttachmentsByFormToken(formToken)
tempWebAttachments.each { TemporaryWebAttachment it ->
log.error("Uploaded attachment name: ${it.filename}")
if(!tempWebAttachments){
throw new InvalidInputException(IssueFieldConstants.ATTACHMENT,
"You must upload attachment")
Swarna Radha
Hi Mark
It is working :)
Swarna
Kristján Geir Mathiesen
Thank you @Mark Markov  Works very nice. Very nice, indeed.
viswa.reddy June 8, 2022
Hi Mark,
Is there a way to make attachments filed mandatory based on custom field value?
for example, I want to make attachments mandatory only when field value = x
we are using jira server with script runner plugin.
Like • Zakhar likes this
Zakhar
September 1, 2022
Hi @viswa.reddy, Do you have the solution for your case? I need exactly the same. Thank you!
Prathima January 31, 2024 edited
Did you get solution for this case ?
Mohamed Adel
August 22, 2018
Hello @Swarna Radha
Please use the following instead with simple script validator:
ComponentAccessor.attachmentManager.getAttachments(issue).size() >= 1
I hope this will help
siva
@Mohamed Adel
Any option to check if the no of attachments are 4 in number.
and for a specific transition.
Michael Kornatzki
November 16, 2020
The solution for the SimpelScriptValidator ends every time in a NullPointerException.
The solution above for the custom script validator works.
Sascha Ziemann
December 10, 2020 edited
This checks, if a issue has something attached. But during the transition the attachment is not yet been attached. This is the reason why the TemporaryWebAttachmentManager has to be used.
